#33249 - 09/16/12 06:50 AM Gridview filter for first three letters
Lyndon_Olfert Offline
Loc: Winnipeg
The first three letters of our customer numbers represent the client and the last three letters represent the program within that client. I would like to see a subtotal by client when I am looking at my outstanding A/R. How would I do this?
Lyndon Olfert, CPA, CGA, CAFM
#33250 - 09/16/12 07:16 AM Re: Gridview filter for first three letters [Re: Lyndon_Olfert]
Create a calculated column using the formula:
Code:
LEFT({Cust #},3)
in GridView and summarize to that calculated column.
#33251 - 09/16/12 08:24 AM Re: Gridview filter for first three letters [Re: Retired_Guy]
Loc: Winnipeg
Thanks Andrew,
I created the calculated column - it works as expected. I created a sort sequence based on that calculated column and applied it to the appropriate filter and checked off the "summarize" box. It does not summarize. The ++ appears but nothing else changes changes. Any ideas of what I might have done wrong?
#33252 - 09/16/12 09:23 AM Re: Gridview filter for first three letters [Re: Lyndon_Olfert]
Have you marked the Balance column to be totaled? You can email me the View if you want.
#33253 - 09/16/12 11:18 AM Re: Gridview filter for first three letters [Re: Retired_Guy]
Deleting and re-defining the calculated column solved the problem.
#33254 - 09/16/12 03:14 PM Re: Gridview filter for first three letters [Re: Retired_Guy]
Loc: Winnipeg
I noticed you put the calculated column in a different location. Does position matter in the result, or was it simply a matter of starting over with the calculated column with all the correct settings?
Thanks for your help. It works very nicely!
#33255 - 09/16/12 03:40 PM Re: Gridview filter for first three letters [Re: Lyndon_Olfert]
Yes - summations are ordered left to right. Having the column to the right of the amount might have been causing a problem. Glad to help.
0 registered (), 459 Guests and 5 Spiders online.
14627 Topics
