#3308 - 04/22/03 12:08 PM Re: Determining Open OE Orders
Dear Sam,
What program are you using to access the OE header record? We need to know that to advise you correctly.
Regards!
#3310 - 04/22/03 01:56 PM Re: Determining Open OE Orders
Hi Sam,
There are a couple of different fields that you might be looking for. I would suggest using Adagio OrderEntry and the Grid Column Editor to track down what you really want...
- An 'Order Complete' field indicates whether the order is closed and there are no more items to ship. I suspect this is what you want.
- An 'Order Release #' indicates how many times an order has been edited or invoiced.
- There are some other fields such as 'Printed status' and 'Costed status', and I believe there is an 'invoiced status' field.
Depending on the particular function you are trying to write, you may require one or more of these fields. It's difficult to advise which are the correct field(s) you want as we don't know what the intended process is, but based on your question, I suspect you want 'Order Complete?'.
