#33019 - 08/28/12 11:57 AM OE Spec Problem
Brian Puddington Offline
Adagio Ace
Loc: Montreal, Canada
Adagio Order Entry 8.1E (120803) both programs and data on Terminal Server Windows Server 2008 R2 Standard.
Printer is Xerox Work Center 7435 PLC6 on \\File Server (redirected)
That means that the printer is not directly connected to the t/s where Adagio resides. It is connected to a file server that is in a separate box.
I have major invoice spec printing problems. First of all, the print preview (not the designer preview) and the printed invoice are quite different. They appear to use different fonts. Secondly, any shape on the form that has been applied by the Adagio form design shape icon prints so feint that it is almost invisible. When I adjust the shape’s border to be larger, it becomes inconsistent with lines on the form that were created with either the horizontal or vertical line icon in the form designer.
Because of the differences between the print preview and the actual printed form adjusting and testing the spec has become very difficult.
Do you think that the problem is because the printer is redirected?
Brian Puddington
Geneva Financial Systems
Montreal
#33020 - 08/28/12 12:24 PM Re: OE Spec Problem [Re: Brian Puddington]
Hello Brian:
Having a printer attached to another server is a pretty common situation and shouldn't be in-and-of-itself sufficient to cause printing problems.
  • Does the printer driver match the Xerox printer? The Xerox site shows drivers for PCL6 and Postscript. What if you tried another one?
  • If printing to PDF, what happens?
  • If you print to that printer from Word/Excel on that T/S, what happens?
If your PDF printing looks correct, how about asking the client to contact their Xerox technician to ask about drivers?
0 registered (), 192 Guests and 1 Spider online.
14672 Topics
