#32992 - 08/24/12 02:34 PM forms and checks printing at 80% size
John_Lipsky Offline
Stranger
Loc: CT
I recently upgraded to a new PC with Win7. Suddenly, a lot of forms have shrunk, printing only about 80% on the paper. A picking slip for example, though this is an internal document, so it's not as critical. However, I've now printed checks from AP for the first time and they printed only about 80% too so NOTHING is aligned correctly. Other things printing from Word etc are ok, even 21st Century Payroll printed our recent payroll checks fine.
No settings were changed in Adagio. The only change was the new PC and Win7.
WHY!!!??? Any suggestions?
#32993 - 08/24/12 02:40 PM Re: forms and checks printing at 80% size [Re: John_Lipsky]
Hi John,
You have Large Fonts set on your Windows Display settings, or the DPI is different than 100%. You need to change Windows to show everything as Normal, what printing forms in Adagio requires.
If you changed Windows to use Large Fonts so that you can see the words larger, a better change would be to lower the screen resolution from the maximum to something a little smaller, so that everything will get bigger.
#32994 - 08/24/12 02:47 PM Re: forms and checks printing at 80% size [Re: Softrak Support]
There is a document in the tips and tricks section of our web site that discusses this.
#33010 - 08/27/12 02:19 PM Re: forms and checks printing at 80% size [Re: Retired_Guy]
John_Lipsky Offline
Stranger
Loc: CT
Thanks for the Large Fonts document. That was it! I had the fonts set to 125%. Setting back to 100% did the trick.
0 registered (), 161 Guests and 2 Spiders online.
14672 Topics
