#325 - 12/07/99 08:30 AM Quick Reports For Windows
When I go into Selection Criteria - the system crashes. CRW.EXE has caused.......
Are their any patches ?
d2
#326 - 12/07/99 11:35 AM Re: Quick Reports For Windows
Hi, D2
QRWIN can crash or give other error messages if you edit/create formulas (selection criteria) if you are using Crystal or A4W on your system as well. There are previous posts on this here in our Forum. You must rename UFLCAPW.DLL in your Windows\Crystal directory. Here is the technote on this:
There are 3 issues with running QRW and A4W:
1. If you cannot edit a formula or a selection formula without getting a GPF, rename the UFLCAPW.DLL in the Windows\Crystal directory while you are using QRW. This file is installed by AFW and it is not compatible with QRW 62A or 62B.
UFLCAPW.DLL adds these Additional functions to Crystal:
PrintNonNull, TranslateType, pwFormatDate, pwFormatTime, LookUpString, SaveNumber, GetBankTotal, TrimZeros, IsTrue.
2. If you have QRW 62B installed and you cannot print a Crystal specification in AFW, rename the UFLMASK.DLL in the Windows\Crystal directory. This file is the Additional function, ApplyMask. It may be used to format item numbers in QRW reports.
3. If you are receiving "Error 515, error in formula" when you print reports in QRW, QIW, CRWIN or QCW, rename the UFLDTDIF.DLL in the Windows\Crystal directory while you are using QRW\QIW\CRWIN\QCW. This file is installed by AFW and it is not compatible with QRW 62A or 62B.
UFLDTDIF.DLL adds this Additional function to Crystal:
DateTimeDiff.
NOTE:
You must reboot your system after renaming the files. When you need to use Crystal or A4W reports again, you may have to rename these files back to their original extension. Some Dealers create a couple of batch files to do this to make it easier.
