Dear Constance,
Assuming that your EZCURFIL.LD4 has been created correctly as a text file and exists on the drive, you should place the location on line 1 of EZCURFIL.LD4 (i.e. if standalone, you would specify drive C:. The location may be c:\softrak\system).
You might want to check that the location you are specifying is in fact the location where your currency codes reside. This can be determined using explorer or under Start (Search, Files and Folders).
The currency codes file name is the MCCODES.LD4
If this doesn’t resolve the problem, there may be other factors at play. Try checking the abovementioned.
