#3228 - 04/01/03 01:40 PM Re: Excel 2000 & Quiklink
Hello Brian,
When you changed the version of Office, you may have changed the version of Excel.
You will need to go through ?Redefining your Excel links?. This is covered in the Quik Link manual on pages 1-13 to 1-15.
#3229 - 04/01/03 01:43 PM Re: Excel 2000 & Quiklink
Hello Brian Bielefeld,
What error messages are you receiving? Quik Link is implemented as a series of VBA macros. There is tighter security in Office 2000. Have you enabled macros to run?
#3231 - 04/02/03 02:52 AM Re: Excel 2000 & Quiklink
Hello Brian,
You may need to reinstall Quik Link, in case the Excel Upgrade overwrote or removed necessary files. Those error messages are being returned from Excel.
In Office 2000, you can set different levels of security for macros. If you have the Macro level security set to Medium, then every time you use Quik Link, you will be prompted whether to Enable macros or not. If the security is High, then you will be unable to run Quik Link at all. Perhaps (temporarily) set the security level to Low and give it a try.
