#31918 - 05/22/12 07:02 AM Odd Bug in POA 8.1B (110325)
MikeS Offline
Loc: Concord, On
Hi - this is more an FYI than a complaint. When I enter a new item on a PO I type the first two letters and then press the down arrow key. 99.9% of the time the first item with those two letters is at the top of the list and is highlighted. I have one two letter combination (XP) that doesn't work - an item with a different two letter combination is at the top and no highlighting. Happened twice this morning. Just thought it was a little odd.
#31931 - 05/22/12 07:19 PM Re: Odd Bug in POA 8.1B (110325) [Re: MikeS]
Hi Mike
You might want to run Data Integrity Check on both PO and IC, there might be a problem with an index file.
#31935 - 05/23/12 05:58 AM Re: Odd Bug in POA 8.1B (110325) [Re: Steve Schwartz]
MikeS Offline
Loc: Concord, On
Hi Steve,
I ran a DIC on inventory - no problem there but didn't think of PO's. Ran a DIC on POA this morning - it came back clean as well. Also ran it on OE just in case. It came back clean also. Open to any other suggestions.
Mike
#31936 - 05/23/12 06:52 AM Re: Odd Bug in POA 8.1B (110325) [Re: MikeS]
Does the Finder in Inventory or OrderEntry show the same behaviour?
#31939 - 05/23/12 08:06 AM Re: Odd Bug in POA 8.1B (110325) [Re: Retired_Guy]
MikeS Offline
Loc: Concord, On
No, works perfectly in those two modules.
#31942 - 05/23/12 08:29 AM Re: Odd Bug in POA 8.1B (110325) [Re: MikeS]
OK - we'll just mark this down as a curiousity. Adagio PurchaseOrders uses the core module Finder technology, so the behaviour should be fixed in the next Upgrade.
14617 Topics
