#31822 - 05/10/12 01:38 AM Need to enable Excel Direct Button on Item Inquiry
chinmook Offline
Edward Chris Chin-Mook
Loc: Jamaica
Can you explain why I have the Excel Direct button when I click - Edit - Item Filters (Create a Filter) but not on the actual Item Inquiry (Display Data Filtered) as a result I am seeing the info I want but can not output ....only on screen.
Need Help ....Thanks
Edward C Chin-Mook
876-754-7444
876-754-5513
#31825 - 05/10/12 06:37 AM Re: Need to enable Excel Direct Button on Item Inquiry [Re: chinmook]
Hello Edward,
What version of Inventory? I'm not getting this behaviour. Can you post a couple of screen shots?
Usually the reason that the ExcelDirect button disappears is that the User Option "Enable SF Export" is disabled under File | Users, but then it should disappear off all screens.
#31831 - 05/10/12 02:43 PM Re: Need to enable Excel Direct Button on Item Inquiry [Re: Retired_Guy]
Excel button doesn't show up in Item Inquiry when a filter is selected and the Find button is disabled too.
Edited by Patricia B. (05/10/12 02:43 PM)
#31832 - 05/10/12 03:23 PM Re: Need to enable Excel Direct Button on Item Inquiry [Re: Patricia B.]
chinmook Offline
Loc: Jamaica
User Option "Enable SF Export" was not enabled.
Thanks Patricia and Andrew. What stump me was it was showing on the screen where I create a filter. That is why I did not check.
Regards
Edward C Chin-Mook
876-754-7444
876-754-5513
#31833 - 05/10/12 03:51 PM Re: Need to enable Excel Direct Button on Item Inquiry [Re: chinmook]
It's certainly there for me in Invenotry 8.1D:
1 registered (Lauren Stief), 257 Guests and 0 Spiders online.
14616 Topics
