#3123 - 02/27/03 09:32 AM FInancial Reporter
Lars Offline
Loc: Vernon, B. C.
I have a client where the 'details' of a field is not available. They have not consolidated and using the 6.8B with the latest ptf. How can I get this feature working?
#3124 - 02/27/03 11:55 AM Re: FInancial Reporter
Hi Lars,
The formula that you are using to output the numeric value will specify whether or not the 'Details' drill-down will be available on the right-click pop up menu.
ADGET, ADDRONLY and ADCRONLY should all be fine, unless you are using the RngMerge function to build the account key. Drill-down won't be available for cells that contain a SUM formula.
If they have Ledger 6.8B, the drill-down should be available and working, whether you are in Print mode or Maintain mode. If it is a particular cell that isn't allowing drill-down, please post here (or email us) what the formula syntax is. If it is for all numeric cells in a financial report, then the problem may lie with the report file itself. If this includes sample reports, then I question that a new enough version is in use.
2 registered (Warren Karges, Douglas Dickie), 135 Guests and 9 Spiders online.
1869 Members
14602 Topics
