#31191 - 03/06/12 10:00 AM System Requirements for Adagio
Can you confirm that this configuration will work with Adagio:
2 Virtual Servers:
Adagio will have it's own VM with MS Windows STD 2008 R2
Everything else will use 2nd VM with MS SBS STD 2011
VMware vSphere 5 Essentials Kit
Workstations currently on XP will be replaced with new machines with Windows 7.
#31193 - 03/06/12 10:56 AM Re: System Requirements for Adagio [Re: SusanTennier]
Adagio has no idea it is running on a virtual machine. If everything is properly set up there should be no problem.
However, if there are problems, then they get very complex very quickly and are impossible to troubleshoot remotely. Experts will likely have to be on site.
#31206 - 03/06/12 04:28 PM Re: System Requirements for Adagio [Re: Retired_Guy]
If configured correctly this will work. Make sure you are working with someone who knows how to do VMware properly. In particular quality of hardware is critical. 4 times out of 5 I have found VMware implemented incorrectly. The result is a very slow Adagio.
14672 Topics
