#31179 - 03/05/12 11:53 AM Order Date Default in OE
MikeS Offline
Loc: Concord, On
Is there a way to stop the order date on the header tab from always reverting to the system date. This happens whenever I re-open an order or copy an existing order. We write up all our orders on an in-house order sheet, then use these sheets to enter invoices into OE. I am currently training someone on our parts system, so they are entering and then saving the orders. I'll go back later and check to make sure the order was entered correctly, then invoice it. But its annoying to have to reset the date each time.
OE 8.1E (120116)
#31180 - 03/05/12 12:44 PM Re: Order Date Default in OE [Re: MikeS]
New orders default to "Today". Existing orders, recalled for edit, do not have the order date changed when I checked this in sample data. Copying an existing order is the same as creating a new order (hence the change of the order date). Check your Entry template to make sure you are visiting the order date field.
0 registered (), 93 Guests and 2 Spiders online.
14672 Topics
