#31105 - 02/29/12 12:43 PM Print progress dialog fails to dispose of itself
SupportGuy Offline
Loc: Victoria, BC, Canada
We are running OE8.1E. We recently installed POA, IC, and BOM, most recent versions.
When I go to Print Invoices, select my range, select my specification, and hit preview or print, the Print Progress form does not dispose of itself after a successful print or preview. Only by hitting ESC does the form properly clean itself up.
Thank you,
#31106 - 02/29/12 01:04 PM Re: Print progress dialog fails to dispose of itself [Re: SupportGuy]
From the Release Note for OrderEntry V8.1E:
Quote:
Added the option 'Close forms dialog after print?' to User Preferences. Deselect this option if you typically print documents to multiple destinations. For example you print a document to printer and also email it. In this case, if you are printingg a range, you will need to select the 'Ask Print OK after forms print?' option and answer No to “Everything printed OK?” after printing to the first destination, and Yes after printing to the second destination.
#31120 - 03/01/12 11:40 AM Re: Print progress dialog fails to dispose of itself [Re: Retired_Guy]
SupportGuy Offline
Sorry Andrew. That did not work.
