#3073 - 02/07/03 12:04 PM Re: Adagio Receivables GL trans to A4W 5.0
Hi Cory,
Adagio Receivables creates a sub-ledger batch file that can be retrieved into Adagio Ledger or Accpac Plus General Ledger with no modifications necessary. There is no 'direct' method to send information to Accpac Advantage series.
If it is still possible to use 'account mapping' in AAS to retrieve Accpac Plus sub-ledger batches, then you can do the same setup to retrieve a sub-ledger batch created with Adagio Receivables.
Note that all the setup would have to be done in AAS GL; there is nothing special that can be done from Adagio.
#3074 - 02/07/03 06:01 PM Re: Adagio Receivables GL trans to A4W 5.0
Hello corey,
Perhaps to clarify.
Adagio Receivables creates a batch indistiguishable from ACCPAC Plus Accounts Receivable. If you were successfully retrieving this batch into ACCPAC Advantage, then your procedure would not be changed.
P.S. I'd be interested in knowing what features in Advantage Series you like best over ACCPAC Plus (which you presumably converted from).
