#30711 - 01/30/12 05:07 PM Payables check posting error: Vendor was in use
Ramona Offline
Stranger
Loc: Burnaby BC Canada
In Payables, while posting a batch for checks where cheque numbers were assigned by Adagio, it gave an error on two cheques saying "The vendor was in use by in ~@." The rest posted and these two are now in an error batch. But all the cheques did print fine, including the two in question. In Check Reconciliation the two have the status P, while the others from the batch are O. Is the P okay? And what is the best way to handle the error batch, now waiting for cheque numbers? If I could just unpost the whole thing, I'd do that, but I don't see a way to.
#30713 - 01/30/12 07:10 PM Re: Payables check posting error: Vendor was in use [Re: Ramona]
Hi Ramona
If it were me, I would print the error batch, then delete it and re-enter it. A status of "P", for practical purposes, means the checks didn't print.
#30714 - 01/30/12 09:14 PM Re: Payables check posting error: Vendor was in use [Re: Ramona]
Can't you just post the error batch, now that the vendors are not in use?
#30717 - 01/31/12 07:10 AM Re: Payables check posting error: Vendor was in use [Re: Retired_Guy]
Brian Stief Offline
Waterloo Guy
We've just run into the same "P" status at one of our client sites using Ap 8.1C. Everything is fine, DIC is clean, except we have a chq with "P" status in the Payables Check Rec.
How do we get rid of the status code? If we click on the check there are no options.
Please advise.
Brian
Brian Stief,CPA,CA
800.540.3164
#30718 - 01/31/12 07:25 AM Re: Payables check posting error: Vendor was in use [Re: Brian Stief]
The "P" status means Posting error.
Print the Check Reconciliation report for checks with the status, Posting error. Say Yes when you are prompted to clear all checks that are not outstanding.
Only the checks with this status will be cleared.
#30720 - 01/31/12 07:29 AM Re: Payables check posting error: Vendor was in use [Re: Softrak Support]
Brian Stief Offline
Waterloo Guy
But it's a valid outstanding December cheque. And we are trying to reconcile the cheques for December.
So it's still a live item, and clearing doesn't solve the problem until the cheq is actually cleared.
Brian
Brian Stief,CPA,CA
800.540.3164
#30721 - 01/31/12 07:53 AM Re: Payables check posting error: Vendor was in use [Re: Brian Stief]
Where there is a posting error, there is an error batch that contains the problem entry.
Once you clear the Posting error checks from the reconciliation, and clear up the problem that caused the posting error, you will be able to post the error batch.
Then you will have the outstanding December check you are expecting.
#30722 - 01/31/12 08:18 AM Re: Payables check posting error: Vendor was in use [Re: Softrak Support]
So, just to clarify.
The "P" status means that the check was printed, but not posted (due to a posting error or some other processing failure). Fixing the error condition will remove the "P" status.
#30723 - 01/31/12 08:46 AM Re: Payables check posting error: Vendor was in use [Re: Brian Stief]
Brian Stief Offline
Waterloo Guy
We did print the Check reconciliation report for just the range of the check with the "P" status with all of the status codes clicked on, and an empty report prints. I get prompted to clear the range, and 0 checks are cleared.
When I print a Check Reconciliation report for several cheques on either side of the check range with the "P" code, with all of the status codes clicked on, all print except for the check with the "P" status. I did not clear checks.
I have confirmed that the cheque is related to a voided transaction that somehow posted properly to the Vendors account, so all of our GL transactions are good. Except I still cannot clear out the check with a "P" status.
I have manually created an outstanding check so that the Outstanding Checks can be properly balanced, and I've dealt with the GL implications for that entry.
And Data Integrity is completely clean.
What I need to know still is how to correct this P status or do I use GV RW?
Brian
Brian Stief,CPA,CA
800.540.3164
#30724 - 01/31/12 08:52 AM Re: Payables check posting error: Vendor was in use [Re: Brian Stief]
Hi Brian,
Please send me the data.
1 registered (1 invisible), 118 Guests and 2 Spiders online.
14624 Topics
