#30070 - 12/07/11 09:57 AM Open Po info
Henry Offline
Loc: Burnaby, BC. Canada
Hi
I am would like to run a report to see what is on open PO
I am confused where to find this info, Can you tell me the Table name I would find this info in
Here are the fields I am looking for
Document Number
Document Type
Order number
Order Date
Vendor Number
Line Ty
Item Number
Desciption
Quanity orginally ordered
Quanity Received
Unit Purchase price
Discount percentage
Discount Amount
Extended order price
thanks
#30078 - 12/07/11 12:00 PM Re: Open Po info [Re: Henry]
Hi Henry,
As Andrew posted in another thread, the best way to find where information can be found in a GridView table is to use the DataDictionaryExporter.exe utility (found in the \Softrak\System directory). This creates a spreadsheet of all tables and fields within.
Even if your report is in Crystal Reports, this utility will still be useful for looking up which table contains desired fields.
These fields will be in either the PO Header or PO Detail files. If you are using GridView and want everythin in a single view window, you will require one of the Composite tables (these tables within the PO dictionary start with 'IR Comp').
#30139 - 12/09/11 10:05 AM Re: Open Po info [Re: Softrak Support]
Henry,
Once again, we are requesting that you contain your posts about a particular topic to a single forum thread from now on.
Thank you.
0 registered (), 104 Guests and 1 Spider online.
1869 Members
14602 Topics
