#29783 - 11/16/11 02:41 PM Toolkit upgrade q?
Treasure S. Offline
Loc: Winnipeg, MB
I recently upgraded the Toolkit for Adagio to toolkit90CSP4 however i'm getting the following message below. Is this something I should be concerned about? I see you can uncheck if you do not want this to appear again. I'm unsure if this message appeared when original product was purchased last year.
“The toolkit has detected unsupported data. Perhaps your Adagio products were upgraded or There is 3rd party data present. The active data function will provide more infor, etc."
Unknown application (EU)
I'm hoping a Tookit rep can respond also. I was unable to post on that forum.
Also I had recently updated AR & Ap to the current releases prior to doing this Toolkit upgrade.
Treasure
#29784 - 11/16/11 02:54 PM Re: Toolkit upgrade q? [Re: Treasure S.]
Bob Wisener Offline
Adagio Conductor
The Toolkit looks at your entire dataset to see if it's compatible with all your modules. It works from a list of known applications. Sometimes, data will be left over from some DOS application. Sometimes it's data from some 3rd party product. Either way, the Toolkit will ignore that data. As mentioned above, the 'Active Data' function will provide more information. Namely, all of your applications and when they were last accessed. If you check the box on the error message, you won't see it again. You are running the latest Toolkit, so it is compatible with all current and past Adagio products. FYI, there is a compatibility chart provided on the Toolkit product page.
Bob Wisener
Dakota Software
#29785 - 11/16/11 02:55 PM Re: Toolkit upgrade q? [Re: Bob Wisener]
Bob Wisener Offline
Adagio Conductor
For future reference, does someone recognize EU data?
Bob Wisener
Dakota Software
#29786 - 11/16/11 03:18 PM Re: Toolkit upgrade q? [Re: Bob Wisener]
Treasure S. Offline
Loc: Winnipeg, MB
Thanks Bob I won't worry about it then at this time.
We did convert from Accpac so that maybe it. We had Fix it, musix (sp)etc years ago also.
I have no idea what app EU is either.
#29787 - 11/16/11 03:20 PM Re: Toolkit upgrade q? [Re: Treasure S.]
Easy Upgrades - a toolkit for Accpac Plus.
#29788 - 11/16/11 03:21 PM Re: Toolkit upgrade q? [Re: Retired_Guy]
Treasure S. Offline
Loc: Winnipeg, MB
thanks Andrew
we did have the toolkit module of plus
#29789 - 11/16/11 03:29 PM Re: Toolkit upgrade q? [Re: Treasure S.]
Bob Wisener Offline
Adagio Conductor
I've added EU to my product list. You won't be bothered by it, on the next release.
Bob Wisener
Dakota Software
14617 Topics
