#29698 - 11/10/11 10:28 AM Gridview Table Question
We regularly use a gridview that I created using the table, "OE Hst Detail/w Head".
Question 1: I don't see where optional fields are available to add to this view. Where are the optional fields and how can I include them in this view?
Question 2: I currently have the view linked to another view created using the table, "AR Transactions" so that we can determine by linking the Doc# if the Invoice has a current amount in AR or if it has a zero balance. This takes about 15 - 20 seconds to load. Too long. Is there a way I can add this info to the OE view using insert related column?
Let me know. Thanks!
#29701 - 11/10/11 11:52 AM Re: Gridview Table Question [Re: SusanTennier]
Hi Susan,
1) The optional fields stored with the order are in the History Header Extension data file. So to get this information, you need to use the composite table '*OE Hist Detail w Head, Head Ext'. You may be able to re-load this table from F4 - View Definition when your view is open, but make a backup of your GV workspace and views before trying this.
2) There is no 'direct link' to the AR Transactions table from the OE History Header table, so you cannot use the 'Insert Related Data' column function. But you can use a calculated column with a GetLinkedValue formula. This would mean ensuring that your existing AR Transactions view has the document number column with the same title as a column in your OE view (and it probably does since you have them currently linked), and both views must be open for this formula to work.
The calculated column formula in your OE view would look something like:
GetLinkedValue("AR Trans View Name","Invoice # column title","Current Balance")
Check out the Help file for formula help (in the Query section of formulas) for more complete information on how to use GetLinkedValue.
#29708 - 11/10/11 01:34 PM Re: Gridview Table Question [Re: Softrak Support]
Amazing!!!! GetLinkedValue is SO much better than a linked view that you have to click through one at a time. :-) Thanks!
2 registered (Bruce Gardner, 1 invisible), 157 Guests and 2 Spiders online.
14673 Topics
