#28248 - 08/03/11 03:41 PM Adagio Purhcase order Registration
Henry Offline
Loc: Burnaby, BC. Canada
We are currntly using Purchase order 2.1. To test the new upgrade, I installed the purchase order 8.1B onto a testing environment.
Now it asks me to Register the software. My question is, should I register it from the testing system ? If I register it now, will I be able to reigister it again from the live system?
Please advise
henry
#28251 - 08/03/11 05:08 PM Re: Adagio Purhcase order Registration [Re: Henry]
Hi Henry
If by "testing environment" you mean that you installed PO 8.1B onto a different network drive or different system than your live Adagio software, then you should hold off.
If you installed it on the live system, and you mean by "testing environment" that you pointed the program at test data, then you should go ahead and register it.
#28252 - 08/03/11 05:15 PM Re: Adagio Purhcase order Registration [Re: Steve Schwartz]
Henry Offline
thank you Steve,
here is what I did, I copied the "adagio data and program folders" onto a different file server and shared them out with the same name as my live system. login into a test PC and mounted those drives as the same drive letter as they were on live system.
in this case, should I register it ?
Please advise
#28253 - 08/03/11 05:22 PM Re: Adagio Purhcase order Registration [Re: Henry]
What's the harm in registering it?
#28254 - 08/04/11 08:36 AM Re: Adagio Purhcase order Registration [Re: Retired_Guy]
Henry Offline
I can not run it without register it
#28257 - 08/04/11 10:30 AM Re: Adagio Purhcase order Registration [Re: Henry]
So what is the harm in registering it? You are on an Upgrade Plan for that module.
1 registered (Samuel Kopstick), 210 Guests and 2 Spiders online.
14630 Topics
