#28111 - 07/22/11 06:43 AM Can't see Acct Codes in View GL Entry window
Carla Offline
CranstC
When I view a GL entry (View Transactions), I am unable to see a column for the Acct code and department. How do I change this so I can see these columns. When I read Help, it shows that I should be able to see this.
#28118 - 07/22/11 09:52 AM Re: Can't see Acct Codes in View GL Entry window [Re: Carla]
Hi Carla
Like almost every grid in Adagio, you can customize the columns. Double-click on any column title, and move the acct and dept fields from the left-hand to the right-hand table.
If double-clicking doesn't work, you need to change a setting under your user ID to allow for customizing columns.
#28126 - 07/22/11 12:17 PM Re: Can't see Acct Codes in View GL Entry window [Re: Steve Schwartz]
Carla Offline
CranstC
Thanks, I think I'm seeing how it works now :-)
1 registered (Tanya_Belanger), 74 Guests and 2 Spiders online.
14630 Topics
