#28074 - 07/20/11 09:14 AM Can't install JobCost on a work station
Carla Offline
CranstC
Hi, trying install Jobcost on a workstation and get the following error:
p:\softrak\ALLWKST\allwkst.exe
No more connections can be made to this remove computer at this time because there are already as many connections as the computer can accept.
Not sure what this means or how to fix it.
Please help! She does have the Invoices and Payables modules set up and can access these.
#28075 - 07/20/11 10:15 AM Re: Can't install JobCost on a work station [Re: Carla]
I may be wrong, but it sounds like you've run out of available connections to your server (some Microsoft server products limit the number of simultaneous connections). That would be a Microsoft issue.
You might try just installing JobCost on the workstation rather than running the All Workstation install.
#28076 - 07/20/11 11:06 AM Re: Can't install JobCost on a work station [Re: Retired_Guy]
Bob Wisener Offline
Adagio Conductor
I've experienced that 'no available connections' problem. The solution was to reboot the connected PCs/Server. Perhaps it's unrelated to the Adagio install.
Bob Wisener
Dakota Software
#28078 - 07/20/11 11:25 AM Re: Can't install JobCost on a work station [Re: Bob Wisener]
Rudolph Engelbrecht Offline
Loc: South Africa
Definitely unrelated to Adagio install. Usually a network limitation / restriction set in Server / Firewall.
Restart will correct and allow you to complete install.
Rudolph Engelbrecht
14617 Topics
