#27904 - 07/06/11 09:43 AM Inactive Items in Inventory & Gridview
Mavis Dai Offline
Loc: Burnaby, BC Canada
In Gridview report, how come some inactive items in Inventory are not showing I in Active Item field? Is there any steps we missed?
Thanks!
#27905 - 07/06/11 11:28 AM Re: Inactive Items in Inventory & Gridview [Re: Mavis Dai]
Michael Mulrooney Offline
What version of IC are you using? See Help | About in I/C
#27906 - 07/06/11 11:38 AM Re: Inactive Items in Inventory & Gridview [Re: Michael Mulrooney]
Mavis Dai Offline
The version of IC is 8.1C. The report is working properly before. Is it related about period end or year end?
#27907 - 07/06/11 11:54 AM Re: Inactive Items in Inventory & Gridview [Re: Mavis Dai]
As in 8.1C (100716) or 8.1C (101104 )?
Does the Data Integrity Check in IC have errors?
If GridView is not showing an "I" is it showing an "A" or is it blank.
If you add the "Active item" to the Item Inquiry Grid what does it show.
#27910 - 07/06/11 05:41 PM Re: Inactive Items in Inventory & Gridview [Re: Michael Mulrooney]
Mavis Dai Offline
8.1C (101104)
No errors - Data Intergrity Check in IC
Other inactive items show I, but those ones show blank
If I add the "Active item" to the Item Inquiry Grid, it shows the same as blank.
#27912 - 07/06/11 06:55 PM Re: Inactive Items in Inventory & Gridview [Re: Mavis Dai]
Are these items being added thru PO?
Do you have PO 8.1B (110325) installed?
Older versions of PO did not know about the "Active item" setting.
#27918 - 07/07/11 11:13 AM Re: Inactive Items in Inventory & Gridview [Re: Michael Mulrooney]
Mavis Dai Offline
Yes,we add these items thru PO.
Our POA is 8.1A (091029)
#27921 - 07/07/11 11:40 AM Re: Inactive Items in Inventory & Gridview [Re: Mavis Dai]
Don't add items to IC using PO 8.1A (091029).
You need to be using PO 8.1B (110325)
#27926 - 07/07/11 12:05 PM Re: Inactive Items in Inventory & Gridview [Re: Michael Mulrooney]
Mavis Dai Offline
Hi Michael,
It was working well before. Do you think we have to install the PO 8.1B (110325)in order to fix this issue?
Mavis
#27928 - 07/07/11 12:15 PM Re: Inactive Items in Inventory & Gridview [Re: Mavis Dai]
Hi Mavis,
In Adagio Inventory versions prior to 8.1C, an 'Active' item used to have a blank value for the active items, and 'I' for inactive items. This changed in version 8.1C so that 'A' is the value for active items.
This is why it was working before with IC and PO - because both applications used blank for active items. Because you upgraded inventory to 8.1C, you must also upgrade PO to 8.1B as Michael indicated to get everything bank in synch.
You should be aware that adding items using PO81A will cause integrity errors to Inventory, and PO8.1B will address this as well.
0 registered (), 52 Guests and 1 Spider online.
1865 Members
14458 Topics
