#21588 - 04/01/10 07:54 AM T5018
JOHN ARANGO Offline
Loc: TORONTO, ONTARIO
Good Morning!!!
Our company deals with a lot of subcontratctors, and and the end of the year, we have to send the T5018 summary to the CRA and the respective one for each subcontractor.
Is there any way in the software to fill out those forms?
Thank you
#21592 - 04/01/10 09:14 AM Re: T5018 [Re: JOHN ARANGO]
You need to turn on 1099 processing (the USA equivalent) and then print the forms using the supplied specification.
#21594 - 04/01/10 09:16 AM Re: T5018 [Re: Retired_Guy]
JOHN ARANGO Offline
Thank You Mr.Bates!!!
#21600 - 04/01/10 11:44 AM Re: T5018 [Re: JOHN ARANGO]
JOHN ARANGO Offline
Hello again!!!
It's semms like the number I obtained in the T5018 do not match with the real total.
Could some body tell me what are the specifications in order to find the total payments for each vendor and see them reflected in the form?
Thank you
#21604 - 04/01/10 12:49 PM Re: T5018 [Re: JOHN ARANGO]
The 1099 amount is the amount that has been paid to a vendor in the calendar year - not the amount that the vendor has invoiced. If the amount is not the figure you expect, then you can just edit the amount in the vendor file.
#27642 - 06/14/11 06:51 AM Re: T5018 [Re: Retired_Guy]
London1921 Offline
Stranger
Hi Andrew:
I am trying to put together a T5018 report for the year ending Dec 31, 2010. I am having trouble understanding why the figure for each and every particular supplier shows as 0 when I preview the report. I also do not understand how we can edit the amount reported in the vendor file if we need to change the figures.
#27644 - 06/14/11 07:26 AM Re: T5018 [Re: London1921]
Do you have the 'Process 1099s?' option enabled in the Company Profile, System/Report Options tab? And, the '1099 Year end' option enabled as well?
Additionally, you need to have the 'Process 1099' option enabled in the vendor record of each vendor you want to gather this information for.
Enabling the above options is necessary to tell the system to start gathering the information.
There is another option in the Company Profile, 'Allow edit of vendor statistics', that when it's turned on/enabled, will allow you to edit the amount reported in the vendor file on the Statistics-YTD tab if you need to change the figures. Normally, this option would be disabled but you can enable it if necessary.
#27647 - 06/14/11 08:07 AM Re: T5018 [Re: Softrak Support]
London1921 Offline
Stranger
Hello again:
I have enabled all the items. The tab for 1099 year end does not have a tick box - just the calendar to note the date required.
When I set up the maintenance specs I moved items around for T5018 reporting format. The field for V13 vendor YTD actually shows a sample figure of over $5 million and when I preview the 1099 report all vendor show $0. What am I doing wrong?
#27652 - 06/14/11 08:49 AM Re: T5018 [Re: London1921]
Look on that vendor's Accounting tab and reconfirm that the 'Process 1099?' option is turned on. Next, check the vendor's Statistics - YTD tab and ensure there is a value in the 'YTD 1099 Payments' field. This is the value that prints using spec code V13.
#27653 - 06/14/11 09:24 AM Re: T5018 [Re: Softrak Support]
London1921 Offline
Stranger
Hello again:
Have confirmed that the vendor's Process 1099 option has been turned on. However, there is no value in any of the YTD 1099 vendor payments' field with that option turned on. I notice that the section in the Vendor's stat - YTD tab for invoices paid shows as 0. We switched to Adagio at the end of Oct 2010 so all history for the 2010 year was taken from our old program (simply accounting). I have done a print out from simply accounting for the 10 months of 2010 so that I would have an idea of the figures to work with. Any more suggestions for me? Thanks
0 registered (), 69 Guests and 0 Spiders online.
1865 Members
14467 Topics
