#2759 - 10/10/02 05:39 PM Q/R DOS & Contact Master for DOS
I need to export notes from Accpac Options Contact Mater to DBase... Does Q/R have tables for CM?
Robert
#2760 - 10/10/02 05:50 PM Re: Q/R DOS & Contact Master for DOS
Hi Robert,
If tables exist for Quik Reports to be used on Contact Master, they would be installed by Contact Master itself. Quik Reports only installs tables for the core Accpac modules, and it is up to the 3rd party products to install the Quik Reports table.
The easiest way to check is to simply open Quik Reports and take a look at the list of 'installed versions' under the Options menu. If you see Contact Master, make sure it is selected. If you don't see it, reinstall Contact Master. If you still don't see it, then a table isn't installed.
