Hello Leo
Adagio can be used on several (multiple) datasets, yes - but you can only have one instance of any Adagio program open at a time on a particular station or PC.
For example, on one PC, you will only be able to open one 'division' with Invoices. When needing to open another 'divison', the first one will be closed.
This holds true even if using different Windows desktop icons to open the datasets.
The ability to have more than one dataset open at a time (i.e. multiple instances of Invoices, or Ledger open at a time on the same PC) is one that has been sent to R&D before on several occasions. Currently, they are in the process of developing this functionality.
It is hoped that this will be able to be implemented in one of the next released Adagio modules. This functionality will use up an Adagio Lanpak for each 'division' or instance of the particular Adagio module being opened.
