#26667 - 03/23/11 12:49 PM AP - Blank Cheque Stock
We have a specification for blank cheque stock in AP. Is there any way for that specification to be selected automatically when we go to AP/Reports/Blank Cheque Stock? Or do we have to search through the list and select the correct one everytime?
#26669 - 03/23/11 12:58 PM Re: AP - Blank Cheque Stock [Re: SusanTennier]
Hi Susan,
The current version of Adagio Payables should remember the last spec you used for printing blank check stock. There is no place to set a default spec code, but the second time you print a blank check it should remember from the first time.
#26675 - 03/23/11 02:22 PM Re: AP - Blank Cheque Stock [Re: Softrak Support]
Hi, Susan,
I'm using AP8.1C(100810) and when I select a spec on the Print Blank Check Stock report window and then Print, the next time I go into the report window, the same spec is remembered.
Do you have Remember Report Settings turned on in your User Preferences?
#26677 - 03/23/11 02:53 PM Re: AP - Blank Cheque Stock [Re: Softrak Support]
I think Susan is looking for a default spec that would be used whenever a blank cheque was requested, whether or not other cheques had been printed in the interim.
#26682 - 03/23/11 05:28 PM Re: AP - Blank Cheque Stock [Re: Retired_Guy]
Actually, now that I've selected "remember report settings" and print to the spec I want, it does remember it. This is great. Thanks.
0 registered (), 492 Guests and 5 Spiders online.
14631 Topics
