#26571 - 03/16/11 11:37 AM Brackets vs. Minus signs in Adagio FX
Grace Offline
New Guy
Loc: Toronto/Mississauga
Some Finance Committee members like minus signs instead of brackets for negative variances on reports. I have been asked to modify my spec file.
Using Format, I can convert (3,325) to -3325. Any idea how I can achive -3,325? I would like to retain the comma.
Any help is appreciated.
Edited by Grace (03/16/11 11:39 AM)
#26577 - 03/16/11 01:18 PM Re: Brackets vs. Minus signs in Adagio FX [Re: Grace]
Hi, Grace,
Select the cell(s) you are interested in using this format for, right click and select Format Cells (or select Format | Cells from the menu). Click on the Format tab. Scroll down the list of available formats until you find the Regional Number format. Select it and click OK.
#26580 - 03/16/11 03:21 PM Re: Brackets vs. Minus signs in Adagio FX [Re: Softrak Support]
Grace Offline
New Guy
Yes, this works like a charm except...
How do I get a rounded number. I tried Precision = 0 and it did not work.
Any ideas???
#26581 - 03/16/11 04:23 PM Re: Brackets vs. Minus signs in Adagio FX [Re: Grace]
Grace:
On the same "Format" screen, try "Comma" as an alternative to "Regional Number". Then you can either set the Precision to 0 on that entry box or close the box and use the "Decrease decimals" button.
#26582 - 03/16/11 04:31 PM Re: Brackets vs. Minus signs in Adagio FX [Re: Bruce Gardner]
Michael Mulrooney Offline
Unfortunately the Regional Setting overrides the Increase/Decrease decimals & Precision that you set.
If you really need this fornatting then you must use Excel Direct and finish the formatting in Excel using Format Cells | Number Decimal places = 0 and select Use 1000 Seperator.
The issue has been reported to R&D and may be addressed in a future release.
#26583 - 03/16/11 04:40 PM Re: Brackets vs. Minus signs in Adagio FX [Re: Bruce Gardner]
Grace Offline
New Guy
Re: Bruce's reply
Yes, I tried this and the negative sign is left justified whereas the number is right justified. The presentation just doesn't look quite right.
Thank you anyway.
Edited by Grace (03/16/11 04:40 PM)
#26584 - 03/16/11 04:46 PM Re: Brackets vs. Minus signs in Adagio FX [Re: Michael Mulrooney]
Grace Offline
New Guy
Re: Michael's reply
I did exactly as you describe ie. the Excel export. This is a great deal of work especially since we have 20+ departments. Ouch!!!
I will wait for the fix and have them settle for dollars and cents if they want minus signs.
I really do not get the fixation with the brackets. Seems to me that committee members get caught up in presentation and forget to analyze the reason for the variances. smile
1 registered (Tanya_Belanger), 139 Guests and 2 Spiders online.
14672 Topics
