#26550 - 03/15/11 05:56 AM Cheque Specs
help Offline
New Guy
I would like to know how to do cheque specs. In manual cheques I do both cash and paments and when I enter an invoice # it does not appear on the portion that the vendor gets. I would like to change this. My bottom portion of the cheque does show my account #ers used which is okay.
#26551 - 03/15/11 06:56 AM Re: Cheque Specs [Re: help]
You modify check specs under Maintenance | Maintain Specifications. You then open up the check spec you want to modify, and make the changes.
You can view a list of all of the spec codes by selecting View | Spec List. Then click on the plus key to the left of Company Information, which expands those codes, and drag "M18 Cash Invoice Number" to where you want it to print.
You can drag other fields around if you need to reposition them on the check. Whatever you do, don't adjust the heights of each section! That's asking for trouble.
Modifying check specs requires more than an elementary knowledge of Adagio. If this explanation is over your head, either watch the recorded webinar on Adagio Payables, or contact your Adagio consultant for help (or read the manual!).
#26552 - 03/15/11 07:01 AM Re: Cheque Specs [Re: Steve Schwartz]
help Offline
New Guy
thank you. Which manuals to you think are the most user friendly for a beginner adagio user?
#26557 - 03/15/11 09:05 AM Re: Cheque Specs [Re: help]
The Adagio Fundamentals manual (the most recent can be downloaded from our website: http://www.softrak.com/downloads/manuals/manuals.php), Chapter 9 deals with the specification designers.
There is also a webinar specifically on using Forms Designer - AP Checks that you can download and watch and learn at your own pace: http://www.softrak.com/support/training/webinars.php
