#2623 - 08/22/02 12:24 PM Re: Some confusion over Lanpak
Hello Scryer21
Hopefully, this little blurb and equation will help you to understand the workings of Adagio Lanpaks...
Adagio Lanpak licensing is used for all Adagio modules, beginning with version 6.8A, except for Crystal Reports for Adagio.
Each Adagio module includes its own module-specific license for a single session. For more than one user to use a module at the same time, an Adagio Lanpak (with generic licenses), must be purchased and installed.
LANPAKS Equation
Sum of (Maximum number of active users for each Adagio module) - (Number of installed Adagio modules) = # of Lanpaks required.
To determine the maximum number of Adagio Lanpaks required for the complete system, sum the maximum number of simultaneous users less one in each Adagio module.
For example - if there will be one user in GL, another in AP, and three in Invoices, the number of Adagio Lanpak licenses needed is 2.
(1xGL ? 1) + (1xAP ? 1) + (3xInvoices ? 1)
= (1 ? 1) + (1 ? 1) + (3 ? 1)
= 0 + 0 + 2
= 2 Adagio Lanpaks
Lanpaks come in 2, 5, 10 & 20 user units.
So, for your requirements, you would need to purchase a 5-User Lanpak, as there is no 3-User.
- 2 AL + 2 AP + 2 AR = 6 Max. Users
- (6 Users) - (3 Installed Adagio Modules) = 3
This means that you would have 2 extra 'seats' available for extra Users.
The only exception to this is Crystal Reports for Adagio...
A separate license is required for each workstation to gain access to Crystal Reports for Adagio. After the first copy of Crystal Reports for Adagio has been registered, a separate Supplemental Copy must be purchased and installed on the local drive of each workstation wanting access.
Regards
#2624 - 08/23/02 03:58 AM Re: Some confusion over Lanpak
We felt this needed further clarification...
The equation quoted above is misleading, as it is assuming that the 'installed' Adagio modules are all in use at any given time.
Your situation is also assuming that there will be a maximum of 2 simulataneous users in each of the separate Adagio module specified.
Adagio modules that are not in use (i.e. not active) do not count in the equation at all. The 1-User license that comes with a particular Adagio module is for that module only and does not get ?used? if that program is not being used.
Does this help?
#2626 - 08/23/02 12:50 PM Re: Some confusion over Lanpak
Dear Scryer21
These are really questions that would be better directed to our Customer Service department, as they have all the information about upgrading and pricing, and if you have registered your Adagio modules, they will have your information and be able to help you accordingly.
Please email them at: customerservice@softrak.com
Alternatively, you could fax them your questions:
(604) 736-6431
Take care,
