#26147 - 02/10/11 05:46 AM OE CN Extended Cost - Problem!!!
Someone brought to my attention today that our avg unit cost is continually inflating on our stock items. I looked in to it and found a huge problem in OE when issuing CN against specific Invoices.
Example: If an Invoice is for QTY 100 of an item at a unit cost of $10 each, the extended cost calculates at $1,000. When we issue a credit against the Invoice and change the quantity to 1, the selling price, extended selling price and unit cost calculate correctly, however the extended cost remains at $1,000 instead of adjusting to $10. This single transaction inflates the total cost of the item by $990 and equally deflates the cost of goods sold. Our inventory value keeps going up while our gross profit looks better than what it really is. Please advise how I can stop this.
I tried a few work arounds but nothing will give us the correct cost calculation when issuing Credit Notes. If you delete all the line items and add a line item, the extended cost calculates at zero. If we issue a Credit without using an Invoice number at all it calculates the extended cost at zero. Even if we calculate the cost manually, we can't enter it in because the field is greyed out.
I checked some Credit Notes from before OE 8.1D was installed and this problem was not occurring then. The cost was calculating correctly on Credit Notes before the upgrade.
Please advise a solution to this!
#26154 - 02/10/11 08:36 AM Re: OE CN Extended Cost - Problem!!! [Re: SusanTennier]
Hi, Susan,
Thank you for reportingt this issue. I've been able to duplicate it and have reported it to R&D for you.
In the interim, the Extended Cost field on the Edit Detail window of the credit note is editable. Please advise your operators of the problem and instruct them to edit the field before clicking OK and posting.
#26155 - 02/10/11 08:54 AM Re: OE CN Extended Cost - Problem!!! [Re: Softrak Support]
I don't normally want the cost field to be editable so I disabled it in Group/Setup/Items but I have re-enabled it for now so we can start using this workaround.
#26157 - 02/10/11 09:45 AM Re: OE CN Extended Cost - Problem!!! [Re: SusanTennier]
Ryan Brohman Offline
Can you roll back from OE 8.1D to 8.1C without repercussions?
Ryan Brohman
Kitchener, ON
#26159 - 02/10/11 09:53 AM Re: OE CN Extended Cost - Problem!!! [Re: Ryan Brohman]
When we installed 8.1D our data was converted. Can it still be rolled back? Is 8.1C the version without filters?
#26161 - 02/10/11 10:28 AM Re: OE CN Extended Cost - Problem!!! [Re: SusanTennier]
This will be fixed faster than you could roll back, and with significantly less disruption.
#26163 - 02/10/11 12:16 PM Re: OE CN Extended Cost - Problem!!! [Re: Retired_Guy]
Andrew:
The sooner the better, thanks.
#26177 - 02/10/11 03:53 PM Re: OE CN Extended Cost - Problem!!! [Re: Douglas Dickie]
A Hot Fix has been posted that fixes this (and several other) issues.
2 registered (Tanya_Belanger, 1 invisible), 621 Guests and 5 Spiders online.
14627 Topics
