#25878 - 01/24/11 11:14 AM
Cancelling Cheques
Casual
I came across the following problem:
Two cheque payments were processed for the same person when they were meant for 2 different people. The resulting single cheque had the total amount on it.
I reveresed the cheque, posted the reversal and then made an adjustment to fix the balance in the debited expense account.
Unfortunately when I go to print new cheques I now see three lines as pending to be printed - those two payments plus the adjustment. Their total is of course zero, but why they still show up in the Payments?
How can I remove them?
Edited by bigcougar (01/24/11 11:14 AM)
#25890 - 01/24/11 03:26 PM
Re: Cancelling Cheques
[Re: Softrak Support]
Casual
Thanks for the help.
Yes, I run Adagio 8.1C
When I go to Payments / Manual Checks there is nothing showing up.
I entered the payments under Invoices. None of the cheques have to be printed.
In the payables they show as:
Vendor / Type / Document / Doc Date / Net Payment ASH / AD / 39-1 / 1/26/2011 / -1000 ASH / IN / HNR19 / 1/26/2011 / 500 ASH / IN / HNR20 / 1/26/2011 / 500
Since I am fairly new to Adagio I am not sure how to get rid of those lines in the Payables.
#25906 - 01/25/11 12:40 PM
Casual
Thanks SS!
I am not sure how to issue "manual cheques" and make the adjustment mentioned.
What I did was, I issued one last invoice for $0.01 and printed the cheque on a piece of paper, then made an adjustment in the GL for 1c.
Is every user supposed to have a consultant?
#25947 - 01/27/11 09:54 AM
[Re: Steve Schwartz]
Casual
I wouldn't say I am proud with how I fixed the problem, but this was the best I could do. I will go through the manuals. Maybe this will help.
Why am I under the impression that you want to make me think I cannot do it on my own, or learn anything without a consultant?
#25996 - 01/31/11 09:08 AM
Casual
Thanks Steve,
I am determined to turn myself into an expert by learning on my own and just asking the occasional question.
I used Manual Cheques to reconcile the invoices and adjustments and ended up in a even more weird situation.
After I posted the manual cheque for $0, I managed to print the Manual Cheque Batch List(Detail) but the posting could not be accomplished. (not even sure what was going to be posted, as no journal entry should result from trying to match an invoive to an adjustment).
There was a message reading that the cheques needed to be printed or they would be written to an error log.
If I tried to print the cheques at the same time , the system would tell me that "there is nothing to print" becuase of the 0 amounts.
Did I miss something in the above explanation? How can I cancel a cheque in Adagio?
#25997 - 01/31/11 10:02 AM
[Re: bigcougar]
Edit the entry in the batch to remove the checkmark on "Print Check". If you want to learn on your own, you should be looking at the webinars at www.softrak.com. There are several dozen from which to choose.
0 registered (),
340
Guests and
2
Spiders online. |
14631 Topics
