#25421 - 12/15/10 01:32 PM Print Check Reconciliation Report
AKW1 Offline
Stranger
Loc: BC, Canada
When I print this report the last 2 (two) decimals do not appear. Instead of 1,000.59, it only shows 1,000 (for example)
Where would I go to correct this?
Adrian Knox-Wilson
250-545-3215 extension 2320
AcuTruss Industries
#25423 - 12/15/10 03:18 PM Re: Print Check Reconciliation Report [Re: AKW1]
What version of Adagio Payables are you using?
Do you use MultiCurrency?
Is this for all checks or just one?
Does a data integrity check reveal any errors?
When Check Reconciliation is open, are then amounts correct here?
Does sample data show the same issue with the Check Reconciliation report?
I cannot replicate the problem using sample data and version 8.1C of Payables. If this is fine for you as well, then the data is the problem and not the report.
I suspect that the check reconciliation data file has one or more checks set with a decimals value of zero instead of 2, meaning the report will print with that value. If an integrity check does not fix anything, then you may need a database repair - provided this is important enough, as the check rec will eventually be purged.
You may want to be in contact with your Adagio consultant.
0 registered (), 135 Guests and 5 Spiders online.
14624 Topics
