Hello Superfly
If Contact Master 2.2 creates/installs a report table that ends with .qrw, then you can use Crystal Reports for Adagio to report off of the data.
Whether or not it can report from the 'extra' data fields found in this version of Contact Master I do not know, as I am not familar with this product and am not able to test this here.
The answer simply would be if the extra fields you are looking for show up on the list in one of the CM tables, then yes - it should read the data found in those fields, however, if these fields are not included or are not showing up in any of the tables, then of course this would not be possible.
If you can in fact insert the desired fields onto a report, and there is no data showing up, then it could be due to improper links, or simply that there is no data in those fields. We would have to know more about the problem before we could offer helpful advice.
