#25080 - 11/22/10 09:57 AM Desktop shortcuts
Deb Offline
Hello, I hope this does not sound like a really stupid question. Here goes...I just noticed that all of the shortcuts for adagio modules have the incorrect version on them. If I open properties it also says the incorrect version. But when I actually open each module I am running the correct version. Do I just rename the desktop icon and I also typed in the correct version on the properties screen. It is just easier to see at a glance from the shortcuts which version I am running. Like I said, hope it's not a silly question..thanks.
#25082 - 11/22/10 10:52 AM Re: Desktop shortcuts [Re: Deb]
No silly questions. Only thing silly is the question unasked.
Shortcut names for Adagio (or other Windows programs) will not auto-adjust based on installing an upgrade with a different version number. Some programs may delete the shortcut and replace it with a new one. Adagio won't do that because you might have put special parameters such as the user ID or the company path on the shortcut and that would be a real pain to replace.
All you need to do is single-left click on the shortcut, press the F2 key to Rename, and type in the version number - as you indicated.
The 'easiest' way to see the actually installed versions of all Adagio programs at a glance is to open any Adagio program (relatively recent release) and from the Help file, pick System Status. This will run the ChkSys utility. Once this is done, there is a 'List Versions' button that will list all the installed Adagio program versions for you. This list will even tell you if there is a more current version of Adagio available that has been released but you haven't yet installed.
14617 Topics
