#2507 - 07/22/02 01:16 PM Re: CR4A 8.5 with Inventory Receipts 6.5(Unisoft)
Hi Ian,
Crystal Reports for Adagio will work successfully with Inventory Receipts 6.5A (I just tried it now), but does not recognize IR6.6A yet, if you try to load it using IRGLOB.DAT. Check your version of IR and I bet it is 6.6A.
To be able to use the XXGLOB data file as a database selector in Crystal Reports for Adagio, we have a translation file that determines the correct table to use for the version of the program you have installed. Because IR6.6 is not in this translation table, you can't directly load IRGLOB as the database selector. We will be adding this shortly as time permits.
As long as you have the QRTIR65A.QRW table installed, you can use ADAGIO.SSI as the database selector, and choose 'All tables'. This will generate a very long list of tables and files to choose from, but your IR files will appear.
From our understanding, IR6.6 did not change in data structure from version 6.5, so the table you have installed already will work just fine.
#2509 - 07/23/02 12:26 PM Re: CR4A 8.5 with Inventory Receipts 6.5(Unisoft)
Good to hear you worked around it! Happy reporting!
