Hi Steve,
If you want to export raw data in a format that your pda can use, there are a couple of options.
The first is through our product Crystal Reports for Adagio, which as the name implies is a report writer based on the Crystal Reports print engine. You could write a report with the fields you wish to use and export to a wide assortment of files.
The second is with a product that is not currently shipping but we anticipate an imminent release. It is called GridView and is a product that can read and display data from any Adagio data file. It also has the ability to export to Excel or HTML format.
Crystal Reports is much more powerful and flexible, but with that power comes complexity. GridView is intended to be very simple to use but does not have as wide a feature set.
