#24638 - 10/25/10 12:51 PM GL 9.0 Upgrades
kruth Offline
Loc: Pennsylvania, USA
I have 9.0A upgrades & service packs from 2007, 9.0B upgrade & service pack from 2009 and now the 9.0C upgrade & service pack. I am presently on 8.1A and planning on getting up-to-date with the times. Do I have to upgrade all or can I go right to the 9.0C upgrade & service pack?
I have upgraded to 9.0C Lanpak, so can I do the 8.1C Payables upgrade before the Ledger?
Re: A/R & Invoices - I heard there were problems with the addresses. I presently have city, state & zip on the 3rd or 4th line (I don't use the zip code box). Will this be a problem when I upgrade? I do not consolidate before pulling into the GL. Are there any other problems I need to fear?
Thanks for any help, Karen
#24640 - 10/25/10 01:16 PM Re: GL 9.0 Upgrades [Re: kruth]
Hi Karen,
You can go directly to Ledger 9.0C. You do not have to install every upgrade versin in between. A significant data conversion will be necessary coming from 8.1A, mostly to allow the soft year end. Ensure you have an appropriate amount of time to do this.
The order of upgrading Payables and Ledger does not really matter. You can choose the program you are most ready to upgrade to go first. There are a couple of integration options within Payables that depend on the Ledger version, so you just need to be aware of this after installing the Ledger update and converting the data.
What problems did you hear about with AR/Invoices addresses?
In general, if you are coming from AR version 8.1 or earlier, the addresses could be converted to a 'formatted' layout to allow merging the city, state and zip code into a single field on forms, and also to allow entry of city and state into specific fields (not just an address line). If you are unsure about this, try the AR90 data conversion with a copy of your data before doing it for real. Then you can see how the addresses get converted and if you are happy with this. The address conversion is optional, and you can do it later (via Import Customers) is you wish.
We don't think there are any problems you need to fear about. But the data conversion for GL and AR will require some preparation before starting. If you are unsure, try it with a copy of the data local before doing it for real. You can have both 8.1A and 9.0 versions of GL and AR and Invoices programs simultaneously, to assist with 'testing' the data conversion with a copy of your data, while still working with your live data.
#24643 - 10/25/10 01:26 PM Re: GL 9.0 Upgrades [Re: Softrak Support]
kruth Offline
What kind of preparation is needed for the GL & AR conversions?
Also, I'm not sure what exactly I need to copy to local drive to test it. I'm not very techie.
#24645 - 10/25/10 01:52 PM Re: GL 9.0 Upgrades [Re: kruth]
Perhaps it's time to ask your Adagio consultant for some help? It's what they exist for.
0 registered (), 341 Guests and 2 Spiders online.
14666 Topics
