#24389 - 10/08/10 02:59 PM Data Integrity Error
BevC Offline
New Guy
Has anyone received the following error during a Data Integrity Check: G/L Account Net Changes 90C...2 error(s)found
If so, how did u resolve it?
#24390 - 10/08/10 03:57 PM Re: Data Integrity Error [Re: BevC]
There was a conversion problem in the initial release of Ledger 9.0C and setting the Active status on the Net Changes records. There was a service pack released in May 2010 that fixes this - either by using the Integrity Check and Rebuild within Ledger, or fixes the conversion from versions of Ledger prior to 90C.
I presume that it has been some time since you did the conversion, so doing a Rebuild after the Data Integrity Check, after installing the service pack, will be the solution. You can get the service pack here from our website.
#24464 - 10/14/10 08:36 AM Re: Data Integrity Error [Re: Softrak Support]
BevC Offline
New Guy
Thank you for your much appreciated assistance - the rebuild corrected the error.
0 registered (), 190 Guests and 3 Spiders online.
