#243 - 10/11/99 05:42 AM Quik Reports 6.1F Cannot open file
I am running WSM 6.5 and QR 6.1F reporting on QI 6.2A on a Novell 4.2 server.
We have recently split the company into four divisions.
Ever since that exercize was finished QR gives me an error only on the newly created companies of "cannot open path\.ext".
If I copy the files to my local drive the report runs fine.
As I mentioned the old company on the server also runs fine.
#244 - 10/12/99 12:38 PM Re: Quik Reports 6.1F Cannot open file
Hello Pieter,
The problem you are running into has to do with the versions of Novell and Client 32 you are running. In newer versions (around Novell 3.0 or so, something within the Novell structure changed so that it interfered with Quik Reports and some other DOS modules. This has been corrected for QR version 6.5A, but you would need to upgrade to get this version. Contact the dealer you work with for the newest version which is Y2K certified and compatible with the Accpac 6.5A releases.
2 registered (Samuel Kopstick, RonaldWilliams), 120 Guests and 1 Spider online.
14673 Topics
