Hello Richard,
This was posted in April:
There are 3 issues with running QRW and AFW.
1. If you cannot edit a formula or a selection formula without getting a GPF, rename the UFLCAPW.DLL in the Windows\Crystal directory while you are using QRW. This file is installed by AFW and it is not compatible with QRW 62A or 62B.
UFLCAPW.DLL adds these Additional functions to Crystal: PrintNonNull, TranslateType, pwFormatDate, pwFormatTime, LookUpString, SaveNumber, GetBankTotal, TrimZeros, IsTrue.
2. If you have QRW 62B installed and you cannot print a Crystal specification in AFW, rename the UFLMASK.DLL in the Windows\Crystal directory. This file is the Additional function, ApplyMask. It may be used to format item numbers in QRW reports.
3. If you are receiving "Error 515, error in formula" when you print reports in QRW, QIW, CRWIN or QCW, rename the UFLDTDIF.DLL in the Windows\Crystal directory while you are using QRW\QIW\CRWIN\QCW. This file is installed by AFW and it is not compatible with QRW 62A or 62B.
UFLDTDIF.DLL adds this Additional function to Crystal: DateTimeDiff.
