#23966 - 09/13/10 12:06 PM adding a new company
Cumberland1 Offline
New Guy
How do I add a new company to A/P, A/R & GL.? Do I need to have a separate data file or can I have it collect the data in the same location as the existing company?
thanks
Donna
Edited by Cumberland1 (09/13/10 12:09 PM)
#23967 - 09/13/10 12:32 PM Re: adding a new company [Re: Cumberland1]
Although it is not strictly necessary, each company's data should be stored in a separate data folder.
#23968 - 09/13/10 01:26 PM Re: adding a new company [Re: Retired_Guy]
General rule of thumb is that if it is a separate legal entity, requires a separate balance sheet just for that entity, or has a different year end date, then it should be in a separate database. Otherwise you could use the same a single database with different departments.
#24065 - 09/21/10 03:46 PM Re: adding a new company [Re: Cumberland1]
Brian Stief Offline
Waterloo Guy
To answer your question, there is a "create" button button on the right of the open window when you open each of your applications, GL, AR, and AP.
You can choose the data path, and yes as was suggested above, you normally choose a separate folder, and separate data extension, but is not necessary.
We normally change the new company to a different background colour in the company profile so you can easily tell which company you are in.
Brian
Brian Stief,CPA,CA
800.540.3164
14672 Topics
