#23908 - 09/03/10 03:51 PM TAX ON MISC. CHARGES
sdaniel Offline
Casual
Loc: BC
I AM USING POA AND CANNOT GET THE TAXES TO CALCULATE ON THE MISC. CHARGES. I HAVE SET UP A SHIP CODE WITH TAX AS HST HOWEVER IT DOES NOT CALCULATE THE TAX WHEN I AM POSTING THE INVOICE. I ALWAYS HAVE TO MANUALLY ADD THE HST FOR THE MISC. CHARGE.
HOW DO I SET THIS UP CORRECTLY.
THANK YOU
#23909 - 09/03/10 05:12 PM Re: TAX ON MISC. CHARGES [Re: sdaniel]
Is the Vendor taxable? If not then no taxes will be generated, regardless of the Misc Charge tax status. You should check the Tax Table that is on the PO/Receipt and ensure that the tax rates have been properly assigned to your HST jurisdiction for the defined statuses.
#23911 - 09/04/10 09:57 AM Re: TAX ON MISC. CHARGES [Re: Softrak Support]
Forum Etiquette: Typing in all capitals IS THE EQUIVALENT TO SHOUTING. Please turn off your ‘Caps lock’ before typing. Thanks.
Sometimes sorting out a tax schema that works in all cases requires significant knowledge of how your database is setup. This may be an issue best handled by your Adagio consultant.
1 registered (RonaldWilliams), 214 Guests and 2 Spiders online.
14673 Topics
