The date on our cheques slowly moves to the right and eventually off the page when we print a cheque run. This just started happening. How do we fix this?
Adagio Payables or Adagio Checks? Version number and release date (you can find this by going to Help|About)? Which workstation operaqting system are you using?
Check your display settings and make sure you are using normal fonts.
Check your Regional Setting and make sure that all three are set to the same thing (Canada or US). This choice must be the one that existed when your check specification was setup.
Douglas Dickie AccSys Solutions Inc Phone: 1.888.534.4344 ddickie@accsyssolutions.com
Softrak Support
Also edit your check spec and for the date field, disable the 'Auto-size' option. I have seen this 'creeping date' behaviour get resolved when removing Auto Size from the check date field.
Regards, Softrak Tech Support
