#235 - 10/02/99 03:27 AM Quik Reports 6.5
QR 6.5 apparently automatically "bolds" subtotals that are inserted into the report (they are block highlighted on screen and printed in bold). I can't see a way to turn this off. The only way I have been able to do this is to use the "Move Block" edit function on a subtotal. After the subtotal is moved the "bolding" is gone.
The bolding is slowing the printing of large reports for a client using a dot matrix printer. (The report in question is one where the details are suppressed, so the Subtotal 1 section is printing on every line of a lengthy report.)
Is there any way to remove this formatting or, even better, to turn off the automatic bolding of subtotals?
#236 - 10/01/99 08:02 PM Re: Quik Reports 6.5
Hi Dean
This is not hard to do, just doesn't get used very often. In order to turn the bolding of the subtotal fields off:
1.Highlite the subtotal you want
2.Select "Edit" from the QR toolbar
3.Select "Block attributes"
4.Press when "Move to start of block" message displays
5.Press when "Move to end of block" message displays
6.Select "Normal" and press Enter to accept the new settings.
In step 5, you can also move to the end of the subtotal line, to select ALL the subtotals in that range.
[This message has been edited by Softrak Support (edited 10-01-1999).]
