#23507 - 08/05/10 04:06 PM hst
Deb Offline
Hello, I have enter all the new tax codes regarding HST and the calculations on our invoices are correct. However, I see on the invoice screen the HST field, but when invoice actually prints out still says GST. I cannot remember how to change this specification. We have several invoice specs that we use. I would also need to have invoices that print only GST total. What is the solution? Thanks.
#23508 - 08/05/10 04:09 PM Re: hst [Re: Deb]
There likely is a text label that specifically is coded as 'GST' on your form. You could make a copy of that form and save it as a new form, and edit the label GST to HST. Now there are 2 forms, one for GST and one for HST.
Alternatively, depending on which application and version you are running, you could insert a database field that prints the tax name, rather than a field label. Thus you would only need one form and it would print GST or HST depending on the Tax Group assigned to the invoice.
#23510 - 08/05/10 04:19 PM Re: hst [Re: Softrak Support]
Deb Offline
How do I enter a database field to do this? Detailed instructions please.Running invoices 9.0A
#23512 - 08/05/10 04:22 PM Re: hst [Re: Deb]
If you're not comfortable making this type of change to your specification document after reading the directions in the Adagio Fundamentals manual, then perhaps your Adagio Consultant can lend a quick hand? You just need to open the specification and select the correct field from the field list in the specification designer.
#23514 - 08/05/10 04:24 PM Re: hst [Re: Retired_Guy]
Deb Offline
Okay thanks very much.
0 registered (), 161 Guests and 2 Spiders online.
14586 Topics
February
