Hi badger,
Adagio Invoices 6.7A is a 16-bit application, which potentially might have issues installing onto a Windows 2000 workstation, depending on how your system is configured. The current release of Adagio Invoices (6.8A) is a 32-bit application.
Also, you must be logged into the station with full installation rights. This is because the workstation setup not only copies files to your C:\windows\system32 directory but also modifies the Windows Registry. If the user does not have full rights, there may exist problems with the workstation setup.
You may want to try re-installing Adagio Invoices onto the network, but from the new station rather than an older one. During the installation, the files that would be installed by the workstation setup are completed during the regular program install. If you run into problems re-installing the program from the CD, you can be sure that the system setup is interfering with the installation.
