Hi Bijithbabu,
To report on Adagio data, Crystal Reports uses a propriatary database driver and tables. It is not through Crystal Dictionaries nor the Access database nor any other type of database.
As long as the installation completed successfully, you only have to use the 'Find Database' function when adding a database to the report. You then can select either the adagio.ssi database driver, or an XXglob file to load the appropriate tables. All of this is described in Chapter 3 of the Crystal Reports for Adagio manual (the smaller one) in a fairly detailed manner, so there's probably too much information to post here.
