Hello Leo
You are not registered for QRWIN - could you please print then fax in the registration form to Customer Service please?
The other thing is that Adagio installs it's own report tables so as such, must be installed after QR or QRWIN IF you want to be able to use the tables that are specific to Adagio. If you do not require the Adagio-specific tables, then you do not have to reinstall Adagio, you can use the corresponding tables from ACCPAC Plus AR, AP, GL, IC and OE with Adagio Receivables, Payables, Ledger, Inventory and OrderEntry. If however, you wish to create a report with Invoices, you need to install Invoices after QRWIN.
No, you cannot just install (or copy) the tables files.
QRWIN has been discontinued - but if you register your version, it might be possible to get the updated release. You should really discuss this with Softrak's Customer Service customerservice@softrak.com or (604) 736-3741, as they will know what you need to do. Otherwise, Crystal Reports 8.5 for Adagio is now shipping, and is the replacement for QRWIN.
To reinstall Invoices, you would have to start with the 6.8A 010711 CD, install it, and then install the most current upgrade (ptf) - you do not have to install every ptf you have, only the most current one.
You can download the most current ptf for Adagio Invoices from the End User area of the website. You will need to obtain the password to unzip the files from your Dealer (Analyst Bay pbg@anabay.ca ).
Since your Invoices' Upgrades plan has recently expired (May 28, 2002), you should renew it to stay current.
