#22943 - 06/25/10 02:36 PM Change Fiscal Year
Rebecca Offline
I am trying to close fiscal year 2009 and one of the steps is to run Change Fiscal Year. How is this done? I've looked at all of the tasks in GL and I can't seem to find what I need.
#22944 - 06/25/10 02:44 PM Re: Change Fiscal Year [Re: Rebecca]
Hi, Rebecca,
Which version of GL are you running? You can find this information by selecting Help then About from the main menu.
If you're running GL9.0A thru C, you need to first Create the Next Year before the Close Current Fiscal Year option can be seen. Both of these options are in the Maintenance menu.
If you're running GL8.1A or earlier, you can find the function in the Maintenance menu also.
#22945 - 06/25/10 02:58 PM Re: Change Fiscal Year [Re: Softrak Support]
Rebecca Offline
The Next Fiscal Year was created. I followed the instructions in the manual that say to select Edit then Fiscal Calendar. My 2010 fiscal year periods are there but when I go to post a journal entry to 2010 it says Edit Batches - 2009. In order for me to get 2010 I have to try to post a batch to Next Year which I don't want to do.
#22946 - 06/25/10 03:18 PM Re: Change Fiscal Year [Re: Rebecca]
If you've already created your Next Fiscal Year, then from what you're saying 2009 is seen as your Current Year (a year in which the last month occurred within 2009) and 2010 is your Next Year. In which case, to post a batch to your 2010 fiscal year, you would click the Next button in the toolbar, enter and post the batch there.
The fiscal year (eg 2009-) that displays is the year your fiscal year ends.
If the batch you want to post to fiscal 2010 is in your Edit Batches 2009- window, you can highlight the batch and use the Copy button to Move the batch to a Next Year, New Batch. After, click Next which will open the Edit Batches 2010- window, locate and post the batch to 2010.
Has your accountant provided you with fiscal 2009 journal entries that have been entered? If so, you'll want to run the Close Current Fiscal Year option located in the Maintenance menu. When this is done, fiscal 2010 will become the new Current Year and the Next button will disappear from the toolbar until it is needed again when it's time to open fiscal 2011.
Even if you Close Current Fiscal Year prior to receiving your accountant's year end journal entries, you are still able to post them using the Post to Prior function (up until you open the Next Year, or 2011).
To clarify, when you create the Next Year, normally you would not edit the Fiscal Calendar. Adagio Ledger automatically creates the next fiscal year calendar for you based on what the fiscal calendar is for the current year.
#22967 - 06/28/10 08:46 AM Re: Change Fiscal Year [Re: Softrak Support]
Rebecca Offline
2009 is our old fiscal year. Our current fiscal year is January 1, 2010 through to December 31, 2010 (also the calendar year). I want our Current Fiscal year to be 2010 and I need to know how to do that because I thought I had followed all of the steps.
Edited by Rebecca (06/28/10 08:46 AM)
#22968 - 06/28/10 08:55 AM Re: Change Fiscal Year [Re: Rebecca]
Hi, Rebecca,
When you close fiscal 2009, fiscal 2010 will move from being the next year to become the current year.
You will find the Close Current Fiscal Year function in the Maintenance menu.
#22976 - 06/28/10 12:07 PM Re: Change Fiscal Year [Re: Softrak Support]
Rebecca Offline
I have already Closed the Fiscal Year. The change to the new fiscal year did not happen. This is my problem.
This has to be the most non user friendly accounting software I've ever used.
#22980 - 06/28/10 01:37 PM Re: Change Fiscal Year [Re: Rebecca]
Hello Rebecca,
What version of Adagio Ledger are you running see Help | About)? There are significant differences between year end processing in these two versions. You mention "One of the steps is to run..." which sounds like you are referring to some kind of document. Is this one that you've downloaded from our web site, or an internally prepared document for your organization?
#22981 - 06/28/10 01:59 PM Re: Change Fiscal Year [Re: Retired_Guy]
Rebecca Offline
It's Ledger 9.0C (100511) and the checklist says Adagio Academy Adagio Ledger Year End checklist courtesy of Ralph Allan, Business Computer Centre.
#22985 - 06/28/10 02:49 PM Re: Change Fiscal Year [Re: Rebecca]
Hi Rebecca,
The tech tip for running a 'Ledger 9.0 Year End' that you are working from does mention that you can see a new fiscal year get created and is visible from the Edit Fiscal Calendar process. But it does not mention anywhere that fiscal year dates need to be changed.
Do any of the fiscal calendars in your Ledger have dates for periods that do not match the year, and if so for which year(s)? Did you change any of the dates in the Edit Fiscal Calendar function? If dates were edited, then this is the source of the problem. I suspect that you have a fiscal calendar '2009-' but the dates were edited to be in the year 2010.
Because your fiscal years exactly match the calendar year, you should be able to look at a fiscal year from the Edit Fiscal Calendar and have all the periods be in the same year as selected. Make a backup of your data, then edit every available fiscal year to have the period dates match the year.
What is the latest fiscal year available from the drop-down? Is is 2009- or 2010-? If the latest year is 2009- then you have not yet run the 'Create Next Fiscal Year' process from the Maintenance menu.
Do you have a 'Next' button on the toolbar to the right of the 'Batch' button? This will indicate that the Next Fiscal Year has been created.
0 registered (), 506 Guests and 7 Spiders online.
14569 Topics
