#22878 - 06/21/10 08:53 AM Print error
Joe Offline
Adagio Fan
Loc: Ontario
when i download a copy of the clients data to my computer (he is using Receivables 8.0A) and go to print i get a message Error 524 Print job busy, close print job. The Payables is fine but it only happens in the Receivables. I do not see this error documented.
Joe
#22881 - 06/21/10 02:24 PM Re: Print error [Re: Joe]
Hello Joe,
A 524 message can be caused by a number of things.
First of all, you will need to reboot your station. If the error happens again, please track when it happens and what you were printing. Also, which version of Receivables are you using?
The error can be caused by an improper installation. You may be trying to print a report that you do not have matching report tables for.
If you are using an old version of Receivables and you are printing to a file, try changing the format or try to print a smaller range.
#22889 - 06/22/10 11:31 AM Re: Print error [Re: Softrak Support]
Joe Offline
Adagio Fan
Loc: Ontario
Thanks - i did resolve it by using an earlier version of qrasp. I renamed the newer one, copied the earlier one over and it worked fine.
Thanks again
Joe
0 registered (), 99 Guests and 1 Spider online.
14632 Topics
